C3 1971 ground wire - NCRS Discussion Boards
C3 1971 ground wire
  • shane barnes
    C3 1971 ground wire
    I replaced the underhood wiring harness that runs across the firewall to the starter. I cannot locate where a ground wire attaches. The wire is black in color with a ring terminal(attaches with bolt/screw). It comes out of the wiring harness close to the wiper motor area. The vehicle is a 71 model, 350/270hp manual transmission, no air, has power brakes. Anyone have an idea where this wire attaches?
    • 15573
    Re: C3 1971 ground wire *TL*
    There is a black wire that grounds to one of the starter motor mounting bolts. Could that be it?
    • Jim T.
      • March 1, 1993
      • 5351
      To back up previous post, my original owner 68 and 70 has a ground wire connected to one of the starter mounting bolts.
        Here's my guess....
        If the black wire exits the firewall harness in the 'Y' area (around/below the WSW motor), my guess is it's the discrete ground for the '71-only CEC control relays that mount on a L-bracket extending from the driver side, upper, firewall. Without a ground reference (L-bracket mounts to non-conductive fiberglass), the CEC system is 'helpless' in terms of operability....
        • shane barnes
          Re: Here's my guess....
          Thanks Jack,
          That is where the wire exits the harness, I'll try that
          • shane barnes
            Jim and Terry,
            I have that ground wire connected. Sorry I didn't mention that in my original post. Thanks though!
              Happy ta help ya!!! *NM*
