Wiper Arm ID - NCRS Discussion Boards
Wiper Arm ID
  • Loren L.
    • April 30, 1976
    • 4104
    Wiper Arm ID
    On a day where the temp has DIPPED to 97 at 3:00 PM, what better than to work in the garage - especially going through the "Wiper Arm Bucket" and trying to figure out what's there. Two UFO's so far:
    1. About 12 3/4" overall when the pivot is IN PLACE; pivot is chrome and the center seems brushed, while the arm seems polished; end of the dips down into an almost semi-circle shape, with one metal "dot"; The arm itself is stamped Trico with a bunch of patents; two rivets on the top hold the center to the arm'
    2. 12 1/2" overall; brush finish pivot; center could be brushed or a POOR SS slightly polished; polished arm; approximately 20 degree bend at the end of the arm, with a metal "dot" on top; TRICO on the underside of the center with patent numbers; an "X" stamped into the blade arm on the underside.
    Film at 11:00...
  • Geoff C.
    • May 31, 1979
    • 1613
    • Loren L.
      • April 30, 1976
      • 4104
      Missed you at the Meet. Dick Bennett
      and I went through all the paperwork looking for the Certificate ......another
      loss due to sloppy administration.
