C2 soft top question - NCRS Discussion Boards
  • Dave Allert
    My soft top rubber seal scratches the paint on the rear of the door when I open and close it. Is this more than likely an adjustment issue with the top, or do I need to replace the rubber seal? How much interference should there be between the seal and the door?
    Dave
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 soft top question
    Corvette Central sells a clear plastic piece that one attaches to the deck lid to prevent the W/S from maring the paint. its available for c-1, 2 and i believe c-3's. Its removable for judging. they are inexpensive. You will continue to experience maring of the paint even if you replace the W/S. the only adjustment that will not allow for maring of paint will allow for wind and rain leakage(ie you'll have to adjust so there is an air gap). mike
