AC A353C air filter element - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    While restoring the air cleaner assembly on my '65 250HP, I found that the original foam/metal screen element has been replaced with the paper element shown on subject line.
    Question: Was this element originally a replacement for the original foam or was it from another application? I like the paper element and would like to purchase a couple of new ones if possible.
    Anyone know of a source for old AC paper air filter elements?
    Gene
    Re: AC A353C air filter element
    Gene----
    The AC A353C has a few other applications, but not very many. At the time that it replaced the original 63-66 A-163C A/C element in November, 1968, it was already in use for a few other applications.
    The A353C is still available from Delco dealers under that part number. It's also available from GM dealers under GM #6484339. It's very unlikely that your Delco or GM dealer will stock this item, so you'll have to buy a case lot of 6 at a time. I think that Dr. Rebuild carries this item so you can purchase quantities of less than 6 from them and, perhaps, other Corvette parts sources.
    • Eugene B.
      • May 31, 1988
      • 710
      Re: Thanks, Joe.
      Joe,
      Thank you for your response and answer to my question.
      Gene
        The Doc also lists the original foam and wire support element.
        • Eugene B.
          • May 31, 1988
          • 710
          Re: Thanks, John
          John,
          I will probably buy an original foam element and screen combination for judging purposes and a couple of paper elements to drive around. I hate the oiled foam elements and the mess associated with them.
          Gene
          • Wayne M.
            • March 1, 1980
            • 6414
            Need (fine) Foam Element w/A165C emboss
            Don't know whether the good Doctor reproduces the original features of # 6418399, but other repro's I've seen are COARSE cell foam and w/NO emboss.
            Finally decided to switch to the paper element A165C, as my original-type foam [bought New-In-Box from an ad in Vette Vues in the early '80's] now turns to dust when touched.
            • Geoff C.
              • May 31, 1979
              • 1613
              Fine Foam but WITHOUT A165C ident. TM *NM*
