Members,
I need/want to replace the rear brake line that runs from under the hood area to the connector in front of the passenger side trailing arm pivot. According to the 1965 AIM, the line runs on top of the frame rail and is secured by three clips. These also appears to be a clip in front of where the trailing arm mounts.
Question: Is it possible to replace this line with the body on the frame? (Please let the answer be yes). I would appreciate input and any "secrets" that will make the replacement possible.
Thanks and regards,
Gene
Thanks and regards,
Gene
