I'm having a minor problem with my Carb. that I can't figure it out. When all the linkage is connected or disconnected and the engine is warmed up(choke seems to be working properly), If I give it gas and let go slowly the engine idle will stop at 1100 rpm. And if I flick the bellcrank the rpm drops back to 850. What could be the source of this sticking or interference in the Carb. Thanks for your thoughts,
Carl
Carl
