After bleeding the two rear brakes to purge the lines of old fluid as a "maintenance" procedure I use, I discovered the pedal now goes half way to the floor before it is hard and it makes a "whoosh" sound as if air was escaping around the brake pedal area. Is this a sign the booster unit is bad?
The pedal if firm --- bled all the calipes several times and there are no leaks.
Bill
Adirondack NCRS Chapter Pictures
Bill
