Kent, where is the ground wire located? Is there a ground wire for each head light bucket?
Re: C2 Head Lights
Re: C2 Head Lights
Hi Mr. Lokay,
Each headlight motor has a black ground wire that attaches to the front header panel support with small sheet-metal screw (if I remember correctly). Easiest way to find is to put fluorecent droplight in front of radiator support and use an inspection mirror (or old vanity mirror, if you can surrepititiously borrow...)
Carl- Top
