Floor Sound Deadner C2 - NCRS Discussion Boards
  • Mike M.
    • September 30, 1999
    • 710
    I've looked in the archives and cannot find the answer to this. I'm installing the sound deadner and carpet in the rear of a 65 coupe. Does the rubber get glued to the floor or is the insulated side down and you glue that to the floor.
    Then the carpet gets glued to the rubber.
    Thanks Mike
  • Patrick T.
    • 1286
    Re: Floor Sound Deadner C2
    I used 3M aerosol Superglue to attach the sound deadner, rubber side down, to the the floor fiberglass, followed by a layer of aluminum tape on top to reduce the heat. Then I glued the carpet to the tape. See below, it worked for me.
    • Jerry G.
      • April 1, 1985
      • 1022
      I'd like to improve the quality of sound deadner over the factory stuff. Who do you recommend as a supplier? Jerry
      • Patrick T.
        • 1286
        In the pictures I posted above, the sound deadner/carpet pad is actually a thin commercial carpet pad. It is only 3/8" thick but is quite dense and heavy. I used this because I happened to have a roll of it handy. You have to cut pleats in it with a razor knife to fit the floor.
        Since it is so dense, it seems to quiet the car noise down quite a bit; the aluminum tape acts as an additional heat barrier. As far as after market items of this sort go, I have heard of a product called "Koolmat" which does a good job. Their website is http://www.koolmat.com/corvette.shtml .
        • Clem Z.
          • January 1, 2006
          • 9427
          would you worry about sound deadening material
          if you are going to install side pipes???
          • Jerry G.
            • April 1, 1985
            • 1022
            Re: Good Question
            This car has original side pipes and it so darn noisy that I'm thinking of putting the sound deadner in the door skins. On the outer interior surface.Not where the vapor barrier is. Has anyone tried this?
              • 11608
              Re: Good Question
              Some aftermarket brands of sidepipes (eg. Allen's vs. Corvette Central vs ?) are much louder than others. I would suggest that different pipes would fix your problem much cheaper and easier.
              Or, sell it and buy one with undercar exhaust.
              Patrick
              • Verle R.
                • March 1, 1989
                • 1163
                Re: Good Question
                Jerry,
                I installed insulation against the outside skin of my doors to help with temperature and sound insulation. I also pulled the kick panels and put insulation there.
                It all helps.
                Verle
                • Eugene B.
                  • May 31, 1988
                  • 710
                  Re: Can't resist, sorry
                  Gents,
                  Guess I'm in one of my moods. Regarding improving the design of the Chevrolet Corvette, I'm remembering the words of David Burroughs in Corvette Restoration - State of the Art.
                  "...The way it was. Not the way we wished it was."
                  Best regards,
                  Gene
                  • Verle R.
                    • March 1, 1989
                    • 1163
                    Gene,
                    You may have it any way you want. :-)
                    Since I was planning to drive on the 50th Caravan from Oklahoma to Nashville/Bowling Green, and did so at the end of June, I chose to make the car a little more comfortable to drive.
                    1600 Miles in a 57 Corvette in June/July was much more pleasant with the insulation.
                    Verle
