I've got 300+ miles on my rebuilt '65 300 hp small block, and things have been going well, until last week.
Due to a malfunctioning (since repaired) fuel gauge, I ran out of gas near home. I filled the tank and immediately found that, on right turns, the car would stumble or die outright. It's an M35 car, so I set the idle a bit faster, thinking that that might cure the problem.
The faster idle did cure the problem, at least for a short time. Last week on 95 degree day, the car started and ran fine for about two hours, remaining at 190 degrees temp. After a couple of hours of great running, mostly below 3000 rpm, it began running poorly. I had a hard time getting it home without stalling. It didn't seem to want to run below 2500 rpm.
During the rebuld, I blocked the carb heater holes in the manifold with 1/2 inch plugs in an attempt to increase the longevity of the carb base (original AFB). The carb has been rebuilt, and was running fine untll lsst week.
Symptoms: Extremely rought idle,even when warm. Doesn't want to idle below 2500 rpm.
You advice is, as always, appreciated.
Mark
Mark
