TI ignition coil - NCRS Discussion Boards
TI ignition coil
  • Jack Farmer
    TI ignition coil
    Hello,
    I am still trying correct problems with my '68 big block. It has TI ignition and I am begining to question the aftermarket coil on the car. It is a "blue Streak UC-12X" . Can anyone tell me if this is a proper replacement for the original "1115207" coil? Can anyone suggest an aftermarket coil that is and has good availability?
    Jfarmer
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: TI ignition coil
    go to www.tispecialty.com/products/coils.htm
    just be setting down before you check out the price.
      Jack----
      The current GM-specified replacement for the 1115207 coil is GM #12337166. This coil also replaces the standard ignition coils. I have heard varying reports about the functionality of this coil when used with TI systems, but it is the coil which GM says is a direct replacement for the '207'. This coil will not be correct in configuration to the original coil, though. It GM lists for about 40 bucks, but is available for much less through Delco dealers.
      • Jack Farmer
        Clem,
        Thank You. What a great site for information and parts. As you said, they are a little pricey, but hey, its a Corvette not a Chevette.
        Jfarmer
        • Jack Farmer
          Joe,
          Thanks, I found a proceedure to test the coil using an ohm meter, I'll give that a shot first. I also got a steer to a website where I can buy a correct coil for a large number of dollars.
          Jfarmer
          • Wayne M.
            • March 1, 1980
            • 6414
            Jack -- If you're using the amplifier box with the new solid state board (from M & H and maybe others) they claim that their modern circuitry performs satisfactorily with the standard (ie. points) coil, although I haven't checked this out.
            • Chris H.
              • April 1, 2000
              • 837
              Jack,
              My 396 would run with the modern amp card and a points coil, but it could not take full-throttle runs to redline. It would break up around 4500 rpm. I could half throttle it 6400 rpm though. Once I put a TI coil in there...full throttle to redline.
              Chris
