If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
When taking off my sill plates(73 coupe), I noticed that there are two plastic orange plugs on each side. These plug into the bird cage channel that runs from the back to the front just under the door. The fiberglass has large holes to accomodate this plug.
Anyone know what the purpose of these plugs were. They almost look like they could be used as pick up points during a body drop.
I've wondered the same myself, but came to the conclusion that the holes are used for visual body alignment during body drop. I don't think you could get any kinda of attachment through the holes because there is only 1/2 inch or so of gap between the bird cage and frame under those holes.
On midyear coupes, there was 1(one) plugged hole under the rocker plate for body attachment--used by verts, but not coupes. Not very familiar with sharks, but may be a similar situation. In midyears, this hole would have been the #2 mount ( 0,1,2,3,4). It only makes sense if sharks had 0,1,2,3,4,5 , and 2&3 were only used by verts.
Their is one hole on each side that goes thru the body and both the top and bottom of the frame. If you put a 1/2 inch rod thru the holes on each side the body should be inline with the frame. It takes a rod about 18 inches long to also rest on the floor. Lyle
I was thinking of using these holes to hold a steel plate(with a bolt) that I want to slide between the bird cage channel and the frame. My bird cage channel is corroded to a point that I don't trust it for a body lift. I would then bolt a 4"x4" angle iron onto the outside where the aluminum sill plate was - sandwiching the birdcage channel and the fiberglass between A and B pillars. This way the whole channel under the door would be temporarily reinforced for a body lift. These holes wouldn't actually see much load - they would only hold everything in place.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
