64 Carter AFB Carb - NCRS Discussion Boards
64 Carter AFB Carb
  • Bob E.
    • April 30, 1999
    • 13
    64 Carter AFB Carb
    I'm having problems with my AFB carb on a rebuilt 300 hp engine. It is running pretty rich. I cleaned it up, put in a kit, check float levels, etc, but no luck. Am I missing an adjustment or something, or is it time for a new one? Any suggestions?
  • Bill Clupper
    Re: 64 Carter AFB Carb
    A few questions to help narrow the search, is the carb running rich with the engine hot or cold or all times? After the rebuild, were the bakelite heat insulator and the stainless steel plate on top of it installed in the correct sequence? Has the choke been adjusted and does it open fully? lastly, were the metering rods installed in the secondaries? The answers to these questions may help start on the way to diagnosing your problem.
    • Bill Clupper
      • Bob E.
        • April 30, 1999
        • 13
        From the looks of the plugs and exhaust, I'd say it runs rich all the time. The gasket, then insulator, then SS baffle are under the carb. (I tried a second gasket above the baffle too) The choke sets fine, warms and releases completely open. The metering rods (refered to as step up rods in instruction sheet?) were installed as before. The ball check in bottom of bowl was replaced. Floats are not binding and in good shape. I noticed the instructions referred to a dash pot that was not in my carb but kit noted parts listed not for all carbs. Rebuilt engine has also been using quite a bit of oil. After 2000 miles, I thought it would settle in! Thanks for any help.
        • Bob E.
          • April 30, 1999
          • 13
          • Bill Clupper
            Bob, are you sure problem is carb? who did the rebuild? How extensive was it? the "using Oil" issue may be a clue, how extensive was the rebuild? Have you tried another carb to verify that for sure the carb is the problem?
            • Bill Clupper
