C-1 Head Bolt Logo's - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Please share with me your collective knowedge about what cylinder head bolt logo/s you would expect to find on an original 1957 Flint 283. Thanks, Dennis
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C-1 Head Bolt Logo's
    our 57 250 hp 210 post, whose engine i removed and disassembled(it had never been apart) contains M logo'd head bolts(the exposed one-- i din't pull valve covers to inspect the longer head bolts).Perhaps YOU should scour the Lyle junkyards for CC logo'd head bolts. believe the abreviation stands for cheaters choke. mikie
    • Dennis C.
      • January 1, 1984
      • 2409
      Thanks Mikie - Knew I could count on you for a fully researched & detailed report on the issue.
      • Dick W.
        • 10483
        Dennis, do you reckon that the "M" stands for missle or mucous????????
        Dick Whittington
          • 15573
          Re: C-1 Head Bolt Logo's *TL*
          If you want a serious answer as to what the M means:
          Depending of the shape of the M - pointed top M is Michigan Screw Products Company, or Midland Screw Corporation, both had the same logo. Rounded top - like a lower case m is Mac-it Parts Company.
          Now the real question is what good does the information do?
          • Dennis C.
            • January 1, 1984
            • 2409
            Well, to me, it's quite obvious - the M stands for Maryland Moron...
            • Mike M.
              • May 31, 1974
              • 8365
              I'm deeply offended.Mucous maryland missile moron.
