Holley Carb - NCRS Discussion Boards
Holley Carb
  • Paul K.
    • February 1, 2002
    • 160
    Holley Carb
    We have a Holley 4160 Carb on a 327/350 1966 vette that whistles after the engine is warmed up, It is a rebuilt one. We are not having any success getting the whistling to stop. Please help
    Paul
  • Michael S.
    • May 31, 2002
    • 91
    Re: Holley Carb
    I had a similar problem on my 1967. Solution was to use two carb base gaskets.The carb body had a small warp, and I have heard this is relatively common.If this is a recent rebuild from a reputable firm however, you should probably not have this problem. I am certain others on the board will offer better advice, but that was my experience.
      Re: Holley Carb
      Vacuum leak.
      • Joe C.
        • August 31, 1999
        • 4598
        Re: Holley Carb
        Paul:
        I assume that it is certainly the carb, and not alternator whine. If you remove the alt belt, and the noise is still present, then it is likely a vac leak. If so, squirt some WD40 on all areas of the carb base while the engine is idling. If the noise is eliminated, and/or the idle speed increases, then you have temporarily sealed a vacuum leak.
        Joe
        • R N.
          • May 31, 2002
          • 640
          Re: Holley Carb
          Paul:
          I had the same problem on my '66 L-72. It only whistled when warm to hot. I thought it was a vacuum leak at first, but after trying different things I found the thottle base plate of the carb was warped between the base plate and the main carb body. I'm in the process of machining a light cut on the base plate to put it straight again. I think this will solve my problem.
          Good luck,
          Kurt Neiman
          • Chas Kingston
            Re: Holley Carb
            Dale would have suggested the application of a baseball bat.
            Geezer
            • Carl R.
              • March 1, 1998
              • 166
              Re: Holley Carb
              Hi Mr. Klemetson,
              Have had similar experience with 1967 327/300 #3810.
              Did your rebuilder replace the small teflon "bearings" on the primary and secondary throttle shafts? With time these can wear & cause an air leak.
              Temporarily (it seems!) fixed mine with two body-to-base gaskets. If not already done, you can tap the two middle/outer base-to-body holes & put two more screws in.
              Carl
