Joe,
In an earlier post, you mentioned that a 1969-era replacement Powerglide converter pan is still available from GM (#3933089). Do you know if it will clear a 168 tooth flexplate? Is the replacement made of steel, or plastic that eventually cracks? This question is not for my Corvette but my '68 Chevelle which now has a 168 tooth flexplate (& later smallblock) with the 'Glide. The original steel pan hits the flexplate. Was '68 the last year with the smaller 153 tooth flexplate and the older starter? Thanks...
