The '65 Tech Manual says (for SB's) "thin flat head 3/4 inch"; (for BB) "bolt head is 3/4 inch across the flats with a thin head approximately 1/8 inch thick"
Are these two descriptions of the same drain plug ?
OK, now what do I have ? -- two different plugs, one has magnetic tip and I got if from a May '65 961 2-bolt 396 big block. It takes a 7/8" wrench (not 3/4") and it's head is a few thou. shy of 1/4" thick. For head marking there's a capital "A" filling a circle of 1/4" dia. at the center of the head. There's also 3 punch marks in a triangle (0.46" to a side) enclosing the center markings. The second drain plug was given to me by a friend who says it came off a '66 L72. It is identical to the first plug except no magnet and absence of the 3 punch dots.
The GM parts catalogs aren't of much help -- the Rev. July 1/65 lists 3779764 for all Corvettes and Passenger (exc. 396 Sp. H/Per.), and 3866916 Magnetic, for Passenger and Corvette w/Sp. H/Per (396). Then, the '67 GM Parts catalog (Oct 1, 1966) calls for 3779764 for ALL Chev's, incl Corvettes, yet goes on to indicate 3866916 (magnetic) for '65-'66 Corvette w/Sp/ H/Per., F.I. (396,327); '65-'66 Passenger w/Sp. H/Per. (396, 427) and '66 Corvette (427).
So... what's right (head size / magnetic / markings) for C2's ?
