1973 Transmission Question
  • Floyd B.
    • November 1, 2002
    • 1038
    The transmission on my 1973 has a switch that I cannot find referenced in the TIM&JG, Corvette Restoration Guide, 1973 Service Manual or 1973 Assembly Manual. It is a cylindrical switch (about 1” in diameter) on the left side of the tranny held in place with a bracket that in turn is held in place by the two cover plate bolts that secure the bottom-rear corner of the cover. The switch is connected to the shifter reverse lever by a bar. Electrically, the switch is connected to the wiring harness in the engine compartment by a thick red and green striped wire.
    Obviously this is a reverse switch that turns on the reverse lights. Can anyone confirm this? Does it have any other purpose? Why is it not referenced in any of the documentation?
    "Drive it like you stole it"
    • 42936
    Re: 1973 Transmission Question
    Floyd-----
    You're correct. The switch that you describe IS a back-up lamp switch. However, the switch used for 1973 ONLY has 2 other functions. It's a neutral safety starting switch AND a seat belt warning switch. The latter function is unique to 1973.
    The switch is GM #6273357 and it's GM-discontinued. However, I think that this switch is reproduced.
    Why is it not referenced in any of the documentation you mentioned? For that, I have no idea.
    • Tom P.
      • April 1, 1980
      • 1784
      Joe,
      You're correct, this switch is reproduced, it's about $50. It was also used on other Chevys as well (early Chevelles).
      • Dick W.
        • July 1, 1985
        • 10485
        Joe, the AIM's that we buy from various vendors are a mere shadow of the original ones. I had a complete '68 that came from GM in Warren that had many more pages than todays repro
        Dick Whittington
