C3 1971 Shoulder Seat Belt Removal - NCRS Discussion Boards
  • Ted Cook
    How do I remove the shoulder belt through the seat back? Planning to recover the seats on my 71 but do not want to damage webbing. Disassemble retractor? If so, how? Thanks.
  • Jack H.
    • April 1, 1990
    • 9906
    Re: C3 1971 Shoulder Seat Belt Removal
    Fold the metal locking tongue backward over the belt fabric, remove the rear seatback bezel and wiggle/sniggle 'er through the opening in the seat. PS, using a hair dryer to heat the rubber buckle/tongue 'web stop' boot, gently stretching and removing it, before folding the tongue back over the belt fabric and beginning removal buys you a LOT more working clearance....
    • Ted Cook
      Hi Jack. Have you been able to remove the rubber buckle/tongue and reinstall without damaging it? It does not seem to be that pliable?
      It you have had success - I'll give it a try.
      • Reba Whittington
        Heat the cover with a hair dryer and remove it VERY carefully. Depending on its age, the vinyl may be brittle.
          • 15573
          Re: C3 1971 Shoulder Seat Belt Removal *TL*
          I have been successful in removing the plastic boots on the shoulder harness with a hair dryer - also have done it in the hot sun, during the right time of year.
          • shane barnes
            Ted,
            I just replaced the seatbelts in my 71. I used Terry's method, hairdryer and gentle persuasion. Worked fine the plastic/vinyl boot did not tear, nor stretch out of shape
