Part numbers - NCRS Discussion Boards
Part numbers
  • Marty McDonough
    Part numbers
    I found the following stuff in a box of what I thought was mid-year parts while cleaning my garage. Any thoughts on what they are from?
    308L40956 - Fuel pump w. AC on body - number is on flange
    3732946 - thermostat housing Actually the 4 looks like it is crossed out with a 7 stamped above it
    14023170 - pulley
    9000513 - Horn dt 4J5
    Thanks in advance, Marty McDonough
    Re: Part numbers
    Marty----
    AC #40956 fuel pump was originally used on 1972 Corvettes with LT-1;
    Water outlet GM #3732946 was used for 1957-58 passenger cars with 6 cylinder engine. GM #3732976 was an exhaust pipe component, so the crossed out "4" must refer to something else;
    GM #14023170 is an AIR pump pulley applicable to many GM cars, including as a SERVICE pulley for many 68-81 Corvette applications. This is a "metric" pulley that SERVICES earlier English-size applications;
    GM #9000513 is a SERVICE horn applicable to 1955-68 Chevrolet passenger cars and Corvettes, as well as many 1955-68 light trucks.
    • Marty McDonough
      Re: Part numbers
      Joe, thank you for your time.
      Marty
