Clutch Vibration - NCRS Discussion Boards
Clutch Vibration
  • Peter Ansted
    Clutch Vibration
    I have noticed that my 63 340 will shake and vibrate when taking off from a dead stop. It doesn't happen all of the time and happens in reverse also. The LUK clutch is 1 year old, the flywheel was re-surfaced when installed. I did use the infamous plastic device when installing the clutch to center it. The clutch seemed to work fine until this vibration and still grabs and shifts strong once engaged. Any suggestion as to cause and remedy are always appreciated.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Clutch Vibration
    Noticed any oil on the floor. Leaks from the rear main can ruin the clutch material.
      Before I'd condemn the clutch, I'd check out the engine mounts and the trans mount for separation, and the diff nose mount bracket bushings and bolt.
      • bruce11495
        What does it run like above 4000rpm? Lots of vibration thru the shifter? I'd be checking the clutch disc if it has the above problems too. The disc can go "egg shape" and go out of balance.........Don't ask how I know. It usually happens to the cheaper model of Luk clutches though.
        • Peter Ansted
          Re: Clutch Vibration -Additional Info
          Thanks for leads - How can I check for failed motor/tranny mount? Floor jack under either, raise slowly and look for movement? How about rear main seal leak? Check behind inspection cover for fresh oil? I am certain snubber is good and I hope seal is good - total rebuild 1 year ago. Also, I do notice a significant vibration through shifter at 60 + mph. Half shafts are balanced, driveshaft is balanced, rear end rebuilt and u joints are new. Thanks for advice.
