I need some advice on the symptoms of a collapsed lifter. I have had to re adjust several lifters on the left bank of a 66 327 CE motor. Without checking with a mike, I think the rocker studs are not moving, the springs are in tact, the adjuster nuts do offer resistance, but not a ton of it. After my latest adjustment (With a hot engine) I was having trouble getting a decent idle, so I shut down and checked all the plugs and did a quick compression check. Right bank 195 - 200, left bank 30, 0, 0, 200. Brought it to tdc and adjusted the #1 valves to just touching, compression came back to 190+/- did the same to #3 and #5 with the same results and all three were tightende down too far (hence the 30, 0 & 0 readings) Started it back up and got the noise out plus 12 turn tighter (I always thought it was 3/4 turn but have heard many differing opinions on that). No noise and ideling much better, but still not perfect. and haven't done a road test yet either. It's ysually after a highway cruise that I get a noisy lifter on that side. If I have a partially collapsed lifter, and adjust the noise out, can the lifter pump up and cause valve to piston problems? Otherwise, any other advice on all this fun??? Thanks in advance!!!
Jim
Jim
