C2 REAR SHOCK PAINTING
  • Rob A.
    • December 1, 1991
    • 50
    #1
    I am preparing to paint the rear shocks on my '67...does anyone know if the grommets securing the lower mounting hooks were originally painted grey along with the shock absorber body?
    • 42936
    Re: C2 REAR SHOCK PAINTING
    Rob-----
    The lower shock grommets were not painted. However, the upper shock grommets, which were installed on the shocks prior to painting, were painted with the rest of the shocks.
    • Rob A.
      • December 1, 1991
      • 50
      Joe
      Joe, I understand that was true of the rear shocks from one of your previous postings. Just to clarify.....on the fronts, the lower grommet as well as the mounting bracket was not?
        • 42936
        Re: Joe
        Rob------
        On the front shocks, the lower grommet and bracket which goes through the grommet and mounts to the lower a-arm were painted with the shocks. The upper grommet was not painted, though, as it was installed at St. Louis.
        • Rob A.
          • December 1, 1991
          • 50
          Thanks Again *NM*
