'64 Wiper Switch - NCRS Discussion Boards
'64 Wiper Switch
  • Brian Brooks
    #31
    Re: One more Problem!
    My continues to fail even in the garage. Thanks for the tip on the turn signal connection. That may be where to look. I can't explain it any other way. Wish me luck!
    • Brian Brooks
      #32
      Re: Do The Check....
      Thanks! There is definitely more than just the switch at play here. Although the original switch was toast! I will do the check, I'm sure that the problem is similar to what you found. Thanks again!
      • Brian Brooks
        #33
        • Brian Brooks
          #34
          Yes, the wipers are working on that side OK.
          • Brian Brooks
            #35
