Harmonic Balancer on 63 Hi perf Fuelie - NCRS Discussion Boards
  • Rainer S.
    • May 31, 2003
    • 468
    I am rebuilding the motor for my Fuelie. The pulley which came with the engine was not the "finned" 8" dia one, pt # 3817173, rather the 8" dia one, without the fins. The timing chain cover and timing tab were also incorrect. The timing mark on the unfinned balancer is a few degrees off in relationship to the keyslot. I was told, that the finned (correct) balancer has the timing mark in-line with the key slot in the bore, The (2) balancers are used with their respective chaincover.
    My questions are:
    1. Is radial position of the crank in the same place,when the balancers are used with their respective chaincover/timing tab location ?
    2. What is better for judging,when buying a replacment balancer; a reproduction from Paragon, or an original balancer with a wrong (later) date ?
    I just cant find an original finned balancer with a date earlier than my engine build date (dec 3,62). I can buy an original one with a later date (63) for $250, or reproduction for $350.
    I am going to use the correct timing chain cover (reproduction from Paragon)
    Any sugestions?
  • Loren L.
    • April 30, 1976
    • 4104
    Where do you live>
    Irrespective of the fact that you are talking about a 40 year old part, I would rather buy and original balancer and an original timing chain cover, pay to have the balancer rebuilt than give up $$$ for an incorrect repro. The prices you quote are way over what I have found at the Pomona swap meets.
    • Rainer S.
      • May 31, 2003
      • 468
      Re: Where do you live>
      I live in Michigan. I went to Paragon today, to pick-up a few parts. Looked at the reproduction harmonic balancer. It looked really close to the correct one, but you can tell the difference. I am waiting for an answer on the original one, that I am interested in. The price of 250.00 is in line of what I have seen on Ebay. I looked for one at last years's Hershey swapmeet, but did not see a single one. I know they are rare. I guess, I may have to settle for one with the wrong date, since you cant see the date after installing the fanpulley, anyway. But I agree, that the Original one is the way to go.
      Rainer
      • Frank H.
        • May 22, 2013
        • 148
        tracys corvettes had them listed in their specials for $125.00
        don't know if its still good?
