I'm getting close to having the engine running and thinking that maybe it needs to be changed. I have a 327 .060 over so I'm looking at 4.060 bore, 3.25 stroke, 56 cc heads, .030 gasket, and flat top pistons. This is showing as 11.72:1 compression which is above the present pump gas. Even doubling the gasket will only bring it to 10.76:1.
Now does anyone know if the 3795896 head is actually 56 cc? I've found various references to 55 cc, 57 cc, and 60 cc for these. Does anyone actually know?
I also have a set of 3725306 that I though I'd use instead but hey ae also supposed to be 56 cc. Anyone know for sure?
Thanks.
Thanks.
