Anyone have the outer dimensions for an auxilary hardtop for a 68-75 Corvette convertible. I need the width (across the decklid), height (at rear of door to top), and diagonally (from windshield frame to the chrome tip). Am trying to determine if it will fit in the rear cargo area of a 1997 GMC S10 Jimmy 4dr. Anyone tried this? TIA, Dave
C3 Aux Hardtop Dimensions
Re: C3 Aux Hardtop Dimensions
Dave measured the top this morning. The width at the rear, point to point is about 47". The distance from the leading edge of a front corner to the opposite side rear tip is 64 1/2-65". The height measured at at the rear of the door to the top is about 13 1/2". If you allow for the extension of the piece that bolts to the side of the top that is used to attach the top with a bolt this would be about 15 inches.- Top
