1963 AIM Help needed - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    All,
    I cannot read the following
    Section 12
    Sheet B9.00
    Title Instrument Panel Harness, Switches & Cig Lighter
    Item 7 Light Switch Asm.
    Part No. ???
    Item 8 Bulb
    Part No. ???
    If any one would please provide the part numbers, I'd appreciate it.
    Don
  • Harry Sadlock
    Re: 1963 AIM Help needed
    Don, this is what I see.
    #7 = 1995095 Switch asm-lgt
    #8 = 274004 Bulb
    Cheers
    Harry
      • 15610
      Item 7 is the light switch assy. p/n 1995095. The bulb, item 8 is 274004. This looks like the bulb for the lighter socket. The engineering change record indiates that this was changed from a 131282. The change was added to this sheet on 3/22/63, but that doesn't tell us when the 274004 actually went into production.
      • Donald O.
        • May 31, 1990
        • 1580
        Thanks for the help ! *NM*
