71 LS5 air cleaner color - NCRS Discussion Boards
  • morgan
    what is the correct finish on the 71 LS5 dual snorkel air cleaner. flat, semi flat or gloss. mine is flat others i have seen are gloss. while on the finish issue what is the finish on the engine compartment?
  • Reba Whittington
    Re: 71 LS5 air cleaner color
    The air cleaner base should be gloss. The engine compartment is semi-gloss.
    • Reba Whittington
        • 11608
        Re: 71 engine compartment color
        Morgan,
        I know it's somewhat a matter of opinion and interpretation, but I might call the engine compartment black-out paint closer to a Medium gloss than Semi-gloss, such as what is seen on you alternator brackets, etc.
        The engine compartment black-out paints from Eastwood or Quanta are quite close.
        Patrick
          • 11608
          Morgan,
          Patrick
          • Wayne M.
            • March 1, 1980
            • 6414
            Patrick --- As the terms "medium" and "semi" both imply a mid-point between flat and glossy, which of the two should be "duller" ?
            • Wayne M.
              • March 1, 1980
              • 6414
                • 11608
                I should have more correctly said either Satin, or possibly "eggshell" rather than medium. In my eyes (and the paint store's), semi-gloss is glossier than Satin or Eggshell.
                Patrick
                  • 11608
                  Patrick
