Craig Schultz if you are out there.....
In an August 31 thread, you gave some information re: set up tolerances. I would like to clarify a couple of things.
1) Side yoke end wear. You mentioned comparing (old vs new) measurements from the inside of the snap ring to the end of the yoke, but didn't mention what that measurement should be. Is there a spec for that?
2) Is there a spec for the center pin diameter? I guess there shouldn't be any wear on it, but I thought I would ask.
3) If .005" to .008" is spec for new set up, mine is way off. My driver side was .05" and my passenger side was .11". There is no apparent wear in the splines on either yoke, i.e. there is no play between the yoke and the sidegear when the yoke is inserted. Will worn clutches create this much end play?
4) Any suggestions as to where I might find a spring compressor suitable for removing the posi springs?
Steve
Steve
