Borg Warner A112HP points for '58 - '73 models - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    I got my special order BW point sets through Pep Boys yesterday, and they are just fine. I would hope so for $18 a set.
    They came in Borg Warner boxes printed with "A112HP" and "Made In USA". I tested one set for spring tension. It took about 32 oz. of pull at the rubbing block to open the points .020". My test set-up was crude, but I think it confirmed that these points do have the slightly higher tension spring band.
    • 15610
    Re: Borg Warner A112HP points for '58 - '73 models
    The common points are 19-23 oz. and the high breaker arm tension type are speced at 28-32oz., so the A112HP appears to be the real McCoy.
    I also recall that the Delco D112P high breaker arm tension set had a larger contact surface than the D106P set.
    Is my memory playing tricks on me, again?
    Do the B-W A112HP appear to have a larger contact area than the common 19-23 oz. point sets.
    • G B.
      • December 1, 1974
      • 1407
      Yep, I think so.
      They look bigger to me and are "ventilated" with a hole in the middle of the stationary side.
      • Jack W.
        • August 31, 2000
        • 358
        Re: Yep, I think so.
        after reading some advice from Duke a while back, I too picked up a handful of these BW points for the higher revving SHP (65 L76 in my garage) since I wanted to stock up on a tune up item. They look like what Jerry describes. And they cost me a bit too - and the boxes looked like they had travelled far.
