OK --- A bit of background for this one --- A 1966 with a L-79 was rebuilt by a reputable engine builder??? New pistons, rings, camshaft, etc was installed as well as a Mallory breaker less ignition module to eliminate the Ignition Points. We noticed the No. 1 spark plug wire location in the distributor cap of a correct car and compared it to this rebuilt motor. This rebuild has its No. 1 spark plug wire in the wrong location in the distributor cap. The engine starts and runs GREAT. The firing order is correct as well as the timing --- the only problem is the location of the plug wires in the cap. In theory, all the plug wires should be moved "TWO spark plug wire positions clockwise". I have a link below showing the correct location for No. 1 CYL.---- and this mystery motors current location. (the photo is from a correct L-79)
How can this motor run so well when the No. 1 cylinder location is two steps from where it should be?
Bill Schroeder NCRS#32822
