62 F.I. distributor seal - NCRS Discussion Boards
  • Richard T.
    • February 1, 1979
    • 858
    The side seal (tach drive) on my 62 F.I. distributor is leaking. I'm ready to replace the seal. Does anyone have an easy way to remove the old seal safely without scarring up the housing? Thanks Rich
  • G B.
    • December 1, 1974
    • 1407
    Re: 62 F.I. distributor seal
    You can make a good tool out of a long narrow screwdriver with a round shaft. I described this tool in a Restorer article about 8 years ago.
    Heat the tip to bend the last 1/4" at a 45 degree angle and grind the edge to seat fully on the seal metal lip. Remove the cross shaft to drive the seal out from the inside. Personally, I can't do this with the distributor in the car. You may be much more skillful than me though.
    • Richard T.
      • February 1, 1979
      • 858
      Thanks! I'll give it a go!
