Looking back at several posts from May of this year there was some discussion on proper operation and configuration of crankcase ventilation/PCV systems especially when combining the earlier and later engine components. Here's my situation: 383" SBC, late 80's roller-cam block, iron Vortec heads with the black centerbolt valve covers to clear roller rockers, RPM alum. intake, Holley. One valve cover has provision for both the oil fill cap and the PCV valve. PCV valve is connected to vacuum at carb base. Other valve cover has NO openings. The fitting on the open-element air cleaner base is plugged off. I've been running this setup for 4 years and approx. 18K miles on my '70 coupe.
My questions/concerns:
1.)it appears that I do not have a fresh air inlet source for the PCV system (unless the later engines used some other source?)- where is the air inlet to the crankcase on the engines that used these valve covers?
2.)would a change in my current setup be recommended in order to draw air into crankcase? What might the consequences be if I continue as is with current setup?
Thanks in advance.
Thanks in advance.
