cylinder heads - NCRS Discussion Boards
cylinder heads
  • Robert D.
    • April 1, 2003
    • 305
    cylinder heads
    i have a 1959 vette # 150 built in sept 58 i have a problem with one of my heads the pad is stamped F909DJ 2x4 245hp i have a chance to get set of heads casting number 3755550 dated I228 sept 22 1958 would this be to late for this motor or would this be a perfect match because its within 2 weeks of the block
  • Robert D.
    • April 1, 2003
    • 305
    Re: cylinder heads
    i also have a chance to get a set set of 58 heads from the last week in may would these be more appropriate
    thanx
    • Mike Cobine
      Re: cylinder heads
      If the engine was assembled on Sept. 9th but the heads weren't cast until Sept. 22nd, it would be a very neat trick in time travel to have those heads be part of that engine.
      I'm afraid they are too late if you want the numbers to all match.
      • Robert D.
        • April 1, 2003
        • 305
        Re: cylinder heads
        how about the 58's
        • Craig S.
          • June 30, 1997
          • 2471
          Re: cylinder heads
          Bob - most of the TIM&JG limits are 6 months prior to the build date of the car, at least in the midyear timeframe. I am guessing C1 is similar. While possible, typical was a lot less, but from the judging view, the 6 month rule usually applies...Craig
