I started the 70 today after 1 year storage. It ran well when put away last fall. It started fine but idles very rough after warm up and backfires through the exhaust while winding down from higher RPM's. The motor accelerates fine in mid range. These symptoms occur while car is parked and without any real load on the motor. Seems like a vacuum advance problem. Any troubleshooting help would be appreciated.
&0 LT-1 trouble shooting help
Re: 70 LT-1 trouble shooting help
I siphoned the gas tank dry prior to starting and put fresh gas in along with a can of dry gas so hopefully the gas situation is OK. Tha AIR is connected and has worked fine in the past. I will remove the AIR belt and see if that helps. any other thoughts???? Thanks- Top
Re: &0 LT-1 trouble shooting help
If you are still using a Holley carb on your LT-1 I think you need to replace the power valve. Using new fuel bowl and metering block gaskets put in a new power could very well fix your problem. With the carb not being used in awhile the gas evaporated during storage and could of attributed to your problem. The parts for this may be available from you local Auto Zone. I can buy power valves, metering block gaskets, and fuel bowl gaskets at my local Auto Zone. It might help if you know the Holley part numbers for these parts when you go.- Top
Holley power valves will have different vacuum openings. The Holley power valves come as one in a blister pack. The last two numbers if I remember correctly will identify the power valves vacuum opening. I am not at home to look in my Holley parts book, but I think your power valve opening is 6.5, so the last two numbers on the Holley blister pack will be 65.- Top
you can check for a blown PV
by putting your finger over the bowl vent with the engine at idle. since the vacuum passage that controls the PV runs straight to a hole on the base plate the added pressure caused by your finger over the bowl vent will force gas into the engine causing it to stall quickly. if the PV is good it takes a while for the added pressure to cause the fuel level to raise in the float bowl and forcing fuel out of the boster nozzles causing the engine to stall.- Top
The potential issue with the A.I.R. is a failed diaphragm in the diverter valve, which fails the spool in the open position so the exhaust manifolds see air all the time - this causes "popping" on overrun, plus a significant vacuum leak. Connect your vacuum gauge to manifold vacuum and note the reading at idle; then pinch the signal hose from the carb base to the diverter valve with your finger - if vacuum increases, the diaphragm has failed.- Top
Re: you can check for a blown PV
Clem I am glad you posted this method of checking the power valve. I discovered this method years ago messing around with my Holley and have used it a few times after discovery, always worked for me. It is a very quick and easy check.- Top
