I have a '72 BB. The car currently has a '74 454 with a HEI distributor. I belive this is the right discription. The distributor is the high efficiency distributor. My current Tach is a mechanical tach, but the distributor has a place for the tack to clip on to at the top not in the stem or shaft. ( I do hope I am explaining this well enough.)
My question is can I convert my mechanical tach to an "electricl" tach to fit my distributor? Dr. Rebuild sells tach. kits and I was hopeing I would be able to buy one to fit my distributor and then rebuild the tach. accordingly.
Any advice would be appriciated.
Thank you,
Brandon
Thank you,
Brandon
