1982 Frame Part Number - NCRS Discussion Boards
  • Donald Brunswick
  • Paul B.
    • April 30, 1995
    • 482
    Re: 1982 Frame Part Number
    Don, out of the many '78-'82s I have ever judged "chassis" on, it's been few that I've seen frame stencils. Usually, the 10,000mi cars and under, it's visible. But, many '78-'82s were undercoated by the selling dealerships so if your car has had this done to it, you WON'T find it unless you clean off the undercoating. The area where the stencil is on these years is just behind the passenger side front wheel. It is usually found on the flat(straight), short section in between the two bends of the frame behind the right front wheel. Sometimes only part of the number is visible because part of it is up behind that metal triangular shaped pan which is in between the frame and right front fender. From what I remember, the ones that have been visible, the lettering, date & part # were UPSIDE DOWN.
