L79 4160 Holley Carb Questions - NCRS Discussion Boards
  • Dave B.
    • April 30, 1984
    • 248
    I will be bringing a '66 with a 4160 LIST 3367 Carb to the Colorado mountains where it will be driven from 6000 to 9000 feet. I want to have the carb redone, and am looking for advice on what to have done. I know that the jets need reducing, and have seen that the primary is around .064 and the secondary .073. Also have read about the 2%/1500' reduction above sea level and that older Holleys were set rich.
    Any advice on settings of jets, power valves, parts that should be replaced, etc, will be greatly appreciated.
    Thanks...Dave
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: L79 4160 Holley Carb Questions
    the LIST 3367 should have a # 65 jet in the pri, a # 22 plate with a .076 drilled holes in the secondary and a #65 power valve from the factory.
    • Dave B.
      • April 30, 1984
      • 248
      Re: Thanks, Clem.....
      I'll apply the 2% rule to these numbers for my final answer.
      Dave
