1968 Brake lights - NCRS Discussion Boards
1968 Brake lights
  • Harmon C.
    • August 31, 1994
    • 3228
    1968 Brake lights
    I am trying to see if this problem could be in the turn signal switch. The brake lights and the four way flashers don't work. The four way flashers work in the front but not in the rear and the turn signals work front and rear as well as all other lights. We have checked the aim the wiring digram the archives and other books. Rear grounds repaired,fuses checked, switch on brake pedal checked, new flasher and bulbs. I have power at pedal switch. Lyle
    Lyle
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1968 Brake lights
    Sounds like the emergency flasher switch to me.
    • Harmon C.
      • August 31, 1994
      • 3228
      Wayne When the emergency flashers are on the fronts work but the rears don,t . Is t he front and rear part of that switch seperate? I have decided the problem may be in the wire after it leaves the brake light switch. With the turn signals working I know the bulbs and the flashers are ok.Lyle
      Lyle
