Condensor for a 69 with Coil#270
  • George Dieterle (34796)
    • September 1, 2000
    • 225
    There is a condensor mounted on the coil bracket. I need to replace it. The wire that attaches to the coil has become brittle and broken off. I tried to read the part number on it, but it's on the under side (bottom) and even with a mirror it's still difficult to read. The part# looks like 5247481 with DR in the middle and some other number which look like PM5. I could take it off, but I'm still not sure if it is the original or a replacement. Can someone tell me what the correct part number for the condensor and any suggestion as to where to get an original replacement?
    George
  • Joe Lucia (12484)
    • 42936
    Re: Condensor for a 69 with Coil#270
    George-----
    The capacitor attached to the ignition coil is for radio interference suppression purposes. The original capacitor installed on your 69 was GM #1947452. That piece was discontinued more than 20 years ago. The 70 style condensor, GM #1852715, will work, but its configuration is different. It's also discontinued, but more recently than the 1947452.
    I don't know if these capacitors are reproduced, or not.
      • September 1, 2000
      • 225
      Thanks Joe *NM*
