i need the correct g.m. part number for a 1966 corvette, 327, 350hp, balancer. is it gm part number 3896903? thank you.
1966, 327,350hp. balancer
Re: 1966, 327,350hp. balancer
Brian----
The correct harmonic balancer for your 1966 L-79 is GM #3817173. This is an 8" balancer which was originally used on 63-65 L-76 and L-84 engines. It was also used on 1965-67 L-79 engines. The original version of this balancer had fin-like casting reinforcements on the internal surface of the crankshaft ring. Although this balancer part number is still available in service from GM, the fin-like reinforcements are no longer used.In Appreciation of John Hinckley- Top
Brian----
