what is the difference between a 64-67 shifter shaft and the 69 -74 sfifter shaft? Length, style etc.? Thanks.
difference 67 & 69 shifter
Tags: None
- Top
Re: difference 67 & 69 shifter
Mike-----
The 68-76 shifter lever is offset somewhat to the right of the shifter blade at the bottom of the lever. The offset is accomplished by the configuration of the rectangular "block" at the base of the round shifter lever. I thought that the 64-67 shifter lever was the same in this regard, but it may not be.In Appreciation of John Hinckley- Top
