If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
A car I am looking at purchasing has a cut in the seat leather. The cut is about 1 1/2 inches long. Can this be patched effectively ( so that you cannot see it ) or does the seat have to come off and be recovered.
If you place your thumb and forefinger at either end of the cut, and spread your fingers slightly. The cut should close pretty evenly. Now, if as you are doing this, you put on crazy glue wood and leather cement, and hold it for several minutes, you should have a solid repair, and if you avoid getting glue all over the place, it will look like a normal leather crease. Beats getting new covers.
Allow me to elaborate on a repair that would be "the same, only different" To maintain the integrity of the torn area consider removing the cover enough to expose the back side of the cut. THEN apply a reiforcement piece to the back side as you bond the edges back together on the surface. A small piece of scrap leather should work just fine for the backup piece. Good Luck. PS, if it does not work just cut the other seat in the same place and swear it is factory correct. (kidding)
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
