I recently rebuit my 4 spd trans and found that it was almost impossible to shift into gears even with the side cover off. If I pry the sliding sleeves just right, they will slide into gear. I think I mixed up the sliding sleeves and clutch hubs. I later read that they are a matched assembly.
How can I determine the correct relationship between the two? Were the assemblies marked any way at the factory, or do I just keep trying them to see which set up slides the best? When I changed the springs and keys they were really hard to slide together.
Boyan
Boyan
