I have a 1969 with a 350 that had headers on it when I bought it. I bought exhaust manifolds on e-bay that were supposed to have come off of a 1968 350 corvette engine. The passenger side manifold had the heat riser valve on it, but I have two questions if anyone knows the answer.
First, the two manifolds are the same height. I thought the passenger side one was supposed to be shorter to accommodate the heat riser. Are the two exhaust pipes leading from the manifold different sizes?
Second, what does the heat riser do anyway?
Thanks in advance for your help.
