I am getting ready to install the rebuild engine on my frame. I purchased a new clutch from LUK (per the Forum's recommendation). I will blachard grind the flywheel next. Should I have the flywheel and clutch assy balanced, or is that overkill ? I am told, that the clutch should have been balanced by LUK before shipping, and the flywheel should be OK. Should I balance ?
Rainer
Rainer
