In my search for a cause/cure for my slightly rough idle on my 72 LT1, I pulled the carb to see if all was in order. I do have a few questions for the carb gurus. There is evidence of a prior rebuild with new blue gaskets throughout.
1. the primary metering block has a 3.5 power valve. What is the logic in doing that since my search of the archives indicates that a 6.5 may be better? Should the secondary block have a 6.5? Mine has a 5.5.
2. is there a home workshop way to check warpage in the metering blocks or the carb base?
3. I have been to the Holley website looking but where do you find out the size of the original needles and jets?
4. is a vacuum gauge the best method for setting mixture? I have always screwed the needles in until lightly seated, backed them out two full turns and then adjusted the idle using a vacuum gauge for highest vacuum. Should both needles be about the same distance out/in?
Gary
Gary
