My 1961 ( very early 10867S1004XX) hood release cable does not say "hood release" on it. The face is not flat. It is a bullet shape on each end. Is this correct? Thanks as always, Joe DeLuca #37862
CI HOOD RELEASE CABLE
Re: CI HOOD RELEASE CABLE
Joe,
If the handle rotates then it is a repro. The originals had a D shaped shaft that will prevent it from rotating. If you are ever going to PV your car, this item will fail you. This is one of those little hidden items on a PV that is not in the Guide and you never know about until a PV judge tells you!
Regards, John McGraw- Top
