I need some assistance regarding the mounting hardware for the AC condenser and the top radiator supports. This is a 454 and I am not for sure there is a difference between it and a 350.
In regards to the condenser mounting, the judging manual states that the condition of the rubber mounting bushing should be checked. I have purchased a mounting kit but their are no rubber washers included. I have also purchased several radiator to core support mounting kits and each has anywhere from 2 - 4 star lock whashers included. The more I look at the assembly manual the more confussing it gets. Neither the condenser bushing or the upper core supports have a clear illustration as to what is required and what goes where. I was hoping that someone could help. I would just like to know the head markings of the four bolts that hold the upper radiator support in place. In addition to holding the radiator support the two inner bolts are used to mount the upper condenser mounting tabs. Just let me know how the washers and bushing are arranged on the bolts and what type of washers are used, example regular lock, flat star lock type.
I was hoping that someone with a original car would respond to my question, since some of the items mentioned above could have possible been disgarded during replacement of a condenser at AC Shop.
